covetsthesun's avatar
covetsthesun
XM Satellite Radio Cutting in and Out
I've Googled this issue and there doesn't seem to be a consensus on the problem or the solution.
Quite a few months back... our XM Radio started cutting in and out. Not often, just a few stations and only in certain areas. Now... it's so frequent we hardly use it. And it's all stations, and seems to be an issue nearly everywhere. But mostly in the more developed areas.
We have a 2004 Silverado with original XM Sat radio gear. It has never been a problem anywhere till this year. This seems to have become a hot issue in a widespread area of the US now.
Has anyone had this problem and did you find a fix for it? We've called XM.. (don't get me started on that) and the radio has been "reset" about 9 times. It cuts out within minutes. Open sky... doesn't matter where you are.
Thanks
  • Possibly a bad connection to the antenna. Happens to me on my portable when the antenna 'pod' is not in a good place.
