HMS_Beagle
Apr 08, 2022Explorer II
BigfootBill wrote:
It looks good. I can see why you would want it behind the marker lights but the gap you need to account for movement of the camper may end up in the same amount of flow as you are having right now between the valence and windshield.
Have you considered combining your new valence with some foam between the camper and rear cab to disturb the flow of air?
From rain and bug patterns there seems to be a flow bubble at the clearance lights and just behind. I think the windshield deflects flow up, then it bounces off the overhang. So a shorter dam back a bit further might do some good, even though clearance would have to be maintained. I liked the position I have as it allows it to overlap the cab vertically, without hitting - but it leaves a gap. I didn't think that gap would be a problem judging from the stagnation of rain droplets towards the top of the windshield, but clearly there is lots of pressure there, enough to distort the valence.
Another thought is to add a rubber chin on the valence that actually contacts the windshield, closing the gap. It would rub, but that might be OK. I might try that at least as an experiment.
44,071 PostsLatest Activity: Aug 30, 2026
