HMS_Beagle's avatar
HMS_Beagle
Yet another Air Dam/Spoiler/Airfoil thingy
Since we don't have enough threads on this already:
I decided to make one, the goal was to reduce wind noise which was more with the camper on than off. Also wanted to reduce the bug count on the camper bulkhead.
I saw some posting in which a guy used a valence (front air dam) for a truck, looked pretty good so I stole the idea. I used the valence for my truck and year model, figuring that it would be the width of the cab. This comes in two versions, a 2WD model about 5" high and a 4WD model about 7" high. It looked like I had room for the 7" so I ordered one (and aftermarket one) for about $110. To attach it, I cut a piece of fiberglass G10 plate, 1/4" thick, to match the valence shape. I CNC cut some recesses in the top side to accept blind nuts, then used 3M VHB to stick it to the camper overhang. The molding was a little floppy and distorted, perhaps because it was aftermarket, though it is about as thick as the one under my truck.
Here is the mount stuck to the camper. I set the tape slightly in from the edge and then caulked the edge with 3M 4000UV to protect the tape:
* Adjusted image size using width=640
  • It was meant to be close to the cab and that's how it came out. When you have something that close you really appreciate how much the camper moves around relative the the cab. But it does not hit. The position was a guess, based on bug patterns, rain streams on the windshield, gut feelings:
  • This is how it looks with the valence mounted. Note the little wave in the middle, this is the distortion in the molding:
