MackinawMan wrote:
Good, with that you should be fine. Do you plan on using any type of WD/Sway hitch?
When we bought ours we had to set up our Equalizer brand hitch in the driveway (had our 2002 Ford Excursion back when that happened).
Keep in mind you might have to do that and budget your time accordingly. I had planned for that and it still took a bit longer than I anticipated.
Thanks Mack, Yes if needed will use a sway bar, but I'm understanding that because of the low wind drag, should not be necessary. It's in the budget if needed. Thanks for all the help guys.
