Roy, thanks. The most I've seen from the panels is 10 amps (max is supposed to be 11.4). I've run some tests, the latest was a 24 hour period where I had only about 30ish ah of charge yesterday because of both the weather and the fact that where my camper is parked I can't get at a whole day's worth of sun. So I ran it all day with what I would consider my normal load. Then I went in at 11pm and measured my voltage, it was somewhere around 12.5v. I turned on my 12v CPAP and let it run all night. 9am voltage was like 12.48v.
Next will be the same test with another day of charging/load to see what my voltage recovers to...if at all. Fun stuff.
I also think that at some point this summer I'm going to run about 30' of 4awg and put a Zamp plug at the rear of my camper. That will be 2/3rd's less loss than I get with my 10 awg 15' extension and give me more range with my panels.
Lastly I am seriously thinking of getting an inverter and installing two outlets...one by the entertainment center and one on the kitchen island.
