rhagfo
Jul 18, 2015Explorer III
So as a driver of a manual 5 speed, I would say more or less normal!
I needed to back into the last two spots up hill with our 11,000# 5er. Reverse is geared higher than granny low and 2nd gear on a manual.
I can't maneuver while rolling at idle in reverse, requires a little slippage of the clutch. That would be the first issue a little chatter, that can shake a lot of things, mine is a little worse as I have a DD clutch. The other would likely be a little axle wrap. Put in low range and unlock the hubs. I can't yet do that with my Ram, getting a 2 Low kit very soon.
44,059 PostsLatest Activity: Mar 18, 2026
