joerg68
Sep 12, 2021Nomad III
the odds of 4 motors failing at exactly the same time are astronomical
Seconded.
Not sure if this will help... I believe, Rieco Titan makes the lift for your camper, but I am not sure. Here is the RT manual:
https://www.riecotitan.com/image/catalog/instructions/electric-roof-lift-instructions.pdf
Thoughts, based on this document:
There is a 25 A fuse that inhibits operation when blown.
Do you have a remote for the roof lift? If so, there is a corresponding control board somewhere in your camper. The board has two relays that may fail. There is also a circuit braker or fuse in line.
Did you try to raise the roof at any time while still latched?
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
