jaycocreek wrote:
I passed on two of the Lifelines because I wanted to float my battereis at a higher voltage than the specified float voltage for the Lifeline model.
So does lifeline batteries take a special charger?I have a Schumacher smart charger with a AGM battery setting,will this work with a Lifeline battery?..Don't know much about Lifeline batteries and how to charge them..
I take care of my RV coach batteries two ways: I charge them through the stock 13.6 volt fixed voltage Parallax model that our RV had in it when we bought it 14 years ago, and I charge them through the stock 130 amp Ford engine alternator whenever the RV engine is running.
I've had two sets of AGM batteries in our RV the whole time (Interstate AGMs for around 8-9 years, and Fullriver AGMs the rest of the time) and have never used a multi-stage charger on the coach AGM batteries.
Since the RV sits in the back yard hooked up all the time between trips, I wanted an AGM batttery that would not be destroyed over time when floated on the 13.6 volts coming from the stock fixed voltage Parallax converter. When I replaced the Interstate AGM batteries with the Fullriver AGM batteries, I almost bought two of the big Group 31 Lifeline 12 volt AGM batteries before I noticed that their specified float voltage was 13.2 volts. I called Lifeline about this and the technician stated that constant floating of the Lifelines at the converter's 13.6 volts would, over time, ruin the Lifelines ("dry them out" is what he stated).
The float spec on the big Group 31 Fullriver batteries is 13.5-13.8 volts ... exactly the range that my Parallax converter operates in. Hence I bought a couple of the Fullriver batteries instead, so that I wouldn't have to replace the perfectly good fixed voltage converter with some kind of multi-stage converter-charger that operated in float mode at the industry standard float voltage of 13.2 volts (which is the float voltage for standard liquid acid batteries and was, at the time, for Lifeline AGM batteries).
The big Fullriver AGMs where only slightly less money than the big Lifelines and are only a couple of lbs. lighter (they're both heavy batteries), and they both have nearly identical Group 31 dimensions.
So ... whenever the engine alternator isn't charging my coach batteries, they're getting charged and floated at the same fixed voltage that the converter sits at all the time ... around 13.6 volts. AGM batteries have very low internal resistance, so unlike liquid acid batteries, they charge fast enough for us on the 13.6 volts from the converter.
To make a long story short ... I could have bought the Lifelines plus a new multi-stage charger for them ... or just the Fullrivers and continue using my stock converter.
Fullriver deep cycle AGM batteries are used all over the world and used to be - and maybe still are - popular in the marine world.
