Supercharged111ExplorerFeb 19, 2022CB Antennas?What CB antennas have you guys had good luck with that are short enough to play nice under a truck camper? I'm curious to see the mounting as well. Obviously a 3 foot fiberglass whip won't fit.
OkieGeneExplorerFeb 24, 2022The shorter the antenna, the more lousy it the reception/transmission becomes.You have to do what you have to do, but that's a lousy idea, the shorter antenna.You need to get at least 1/4 to 1/2 wavelength, and decent coax and connectors. Most CB coax is junk and the connectors are too.Best wishes to you.
