did you still need the airbags at that point? to me the best suspension is one you build good enough you don't need air bags, and yes I did use them on my 98 f150 with my old pull behind trailer. changed to timberins threw the airbags in a corner of the garage and never looked back. I should dig them out and put them on the buy and sell one of these days.
- Camper_Jeff___KFeb 15, 2025Navigator
I use the airbags to trim and level the truck and camper. The new rear springs are 6+1 leaf's, and rated 4400# each. The front springs were sagging so I replaced them with 3 leaf springs. After the new front leafs were installed, unloaded, the truck unloaded, sat 42" high at all 4 corners measured from the ground, to the wheel well center above the axles. The camper weight lowers the rear a couple inches and the airbags can now bring the truck carrying the camper back to level.
- StirCrazyFeb 16, 2025Moderator
I am confused a bit, are you making it level or are you bringing it back to the empty hight, and if the latter was that level or a little high in the back like trucks should sit so they are level when they have the load on?
- Grit_dogMar 07, 2025Trailblazer
This is basically a solution looking for a problem and a hobby tinkering with the truck and camper. All good.
we all look at things different and it ain’t always right but it’s alright.
