I use the airbags to trim and level the truck and camper. The new rear springs are 6+1 leaf's, and rated 4400# each. The front springs were sagging so I replaced them with 3 leaf springs. After the new front leafs were installed, unloaded, the truck unloaded, sat 42" high at all 4 corners measured from the ground, to the wheel well center above the axles. The camper weight lowers the rear a couple inches and the airbags can now bring the truck carrying the camper back to level.
I am confused a bit, are you making it level or are you bringing it back to the empty hight, and if the latter was that level or a little high in the back like trucks should sit so they are level when they have the load on?
- Grit_dogMar 07, 2025Trailblazer
This is basically a solution looking for a problem and a hobby tinkering with the truck and camper. All good.
we all look at things different and it ain’t always right but it’s alright. - Camper_Jeff___KFeb 16, 2025Navigator
This truck is setup to ride level unloaded. If I put 2000 pounds of concrete in the bed, it drops down but is close to level. If I put a 3000 pound TC with another 500 pounds of our stuff in it, the truck will drop a couple inches even with those big springs which I am pretty sure provide more weight carrying capacity than adding a pair of Timbrens with bump stops. The left side of the TC seems to be heavier and causes a slight left lean. The airbags allow me to compensate for ride height and to correct the left lean. I get back to a pretty level, normal ride using the airbags. Headlights aren't pointing into oncoming faces.
- valhalla360Feb 28, 2025Navigator
Did you custom set the springs, so it rides level empty? Stock, the rear aways sits a bit high, so adding beefier springs would typically increase that. If so, why didn't you keep the normal spacing?
- Grit_dogMar 12, 2025Trailblazer
^They could vary we’ll be and likely are stock type replacements.
some Super duty’s of that era had a heavy front spring package. Call it a snowplow package or whatever. Came from the factory “leveled”. And rode like a lumber wagon. Had a bunch of early superdoodys in the fleet with this package. Looked like a 2” front port basically.
- StirCrazyFeb 17, 2025Moderator
ahh ok, I was hoping with heavier springs you wouldn't need them, setting up the springs is always the best option.
