Here's a gripe, it's hard to keep track of replys because replys don't attach to who the reply and it all gets mixed and you can't connect the dots of who's who after there are several replies.
I think there is a option in your settings to put it back to threaded again. when that first came out it was confusing but I'll play with it and let you know how to do it.
Ok so if you click on your name on the top right, then My settings. then preferences and down under reply's and coments, pick threaded instead of linear.
- MORSNOWApr 15, 2025Navigator III
That does change it. I had mine at linear also and just changed to threaded. But if I reply to a post in the middle of the thread, is my post mixed up in the middle, or does it go at the end of the thread?
- StirCrazyApr 16, 2025Moderator
it went inline for this one.. what I don't know is if I will get the new message highlighted and that was the issue before when they were threaded by default a replay would come in somewhere in the middle of a 5 year old post and you would have to search for it.
