workhardplayha1's avatar
Dec 21, 2013
F-550 chassis
I saw the Thor units. Are there any other manufacturers building on the F-550 chassis? (I did see Bornfree and Host but the floor plans don't work for us.
  • OpenRangePullen_Ford wrote:
    Yes Dynamax the builders of the $164k C-class built on a E-450. What a Waste of money.
    There's nothing wrong with the E450 being the starting point chassis for Dynamax's compact, slide-less, great looking, almost superbly outfitted Class C.
    What you're most likely paying primarily for is Dynamax's extensive use of molded fiberglass for the roof and walls, plus a fairly good appliance and equipment list - including DynaRide air suspension in the rear to defang the E450's rear ride beast.
    What I would not pay that kind of Class C money for is it's small capacity liquid tanks.
    If it wasn't for those small tanks, I'd love to have one of those ISATA E-Series IE235 Class Cs with larger diameter tires and upfitted to 4X4 drive. :C
  • I think Thor is the only one building with floorplan, master bed and cabover bunk.
  • I've seen the units you refer to-I'm not in the market but think the idea of a crew cab with 4 captains chairs in a 4x4 F550 would be awesome comfort and safety wise with a big C built behind it. Even if you don't need the crew I highly recommend it.
  • rvten wrote:
    Dynamax
