Grit_dog
May 04, 2023Trailblazer
^I get it. Whatever works best for you is what works best.
The big thing with moisture is volume introduced via external stuff (the wet ski gear) and the lack of good air circulation. The forced air furnace (mouse turd burner lol) does a lot to dry the air but trust me. Few people for a few days in cold weather in a TC will be a challenge to keep humidity and condensation under control. You can. It’s not prohibitive, just a bit of a challenge.
You can charge from the truck somewhat efficiently with a good size DCDC charger.
Still, your engineer sense should guide you from over complicating things like plumbing into the truck fuel tank. Besides those little heaters only use like a half gallon of diesel a day or something minuscule. Nothing a little fuel can and 5 min a day can’t keep full.
If I have any control over it I WILL be doing very similar to you again in the future. And having run a couple TCs thru the gamut from driving to AK to outrunning tornados in the Midwest and boonie docking in the Rockies and cascades, what you’re planning is a great setup.
Cheers!
Cheers!
About Truck Camper Group
300 PostsLatest Activity: Aug 21, 2026
