StirCrazy
May 05, 2023Moderator
mbloof wrote:
It is my understanding that much like a propane furnace a "diesel heater" (read - actually a furnace) draws combustion air from the outside and vents its exhaust to the outside.
The "flame" heats one side of a "heat exchanger" where cabin air is drawn in and blown out on the other side of it.
The CLAIMED current draw of some of the models available are less than the stock OEM Atwood/Suburban/?? propane furnaces.
- Mark0.
The 5KW model I was looking at (still am) uses 36 watts at full power. that's about 0.5 amp less than my furnace that has 1/2 the BTU. so not a huge reduction when it's running full out. here is the espar rating for a similar output as my furnace.
my furnace is 7800BTU
" Fuel Type Diesel
Heat Output 2200W (7500BTU)
Fuel Consumption 0.02 - 0.1 gal/h (0.06 - 0.28 l/h)
Power Consumption 6 - 31W
Rated Voltage 12V"
So, it is quite feasible that I could cut my power usage in half with an espar unit and make my propane last a lot longer in the heating seasons. Also, diesel is a lot easier to find than propane in a lot of the places I go. but I am also looking at Hydronic systems and trying to figure out how hard it would be to retrofit one in.
About Truck Camper Group
300 PostsLatest Activity: Aug 21, 2026
