3 tons wrote:
Not unlike a 2x4, the advertised 2” wall thickness is merely a nominal figure whereby 2” camper wall thickness is actually at 1.5”, but still good and not to be dismissed…
3 tons
I think in the case of artic fox they use 2" aluminum square tube for the frame so the wals would be slightly over 2" at least that what they say is the major difference between the artic fox and the wolf creek line which only uses 1" alumium tubing I did have a actualy construction sheep here from the manufacture I'll see if I can find it and confirm that
Steve
