errante wrote:
I posted on this old Lance 830 thread because It would hopefully elicit the most knowledgeable responses. My camper is a Lance 830. I was camped in New Mexico in calm weather and a sudden wind gust pulled one of my windows up and threw it 20 feet. It damaged the lense but nothing gorilla tape couldn’t fix. Been that way for 5000 miles. Time to fix it. Talked to Lance. The window and its replacement are no longer made. Talked to several other suppliers/manufacturers, same answer. Talked to San Diego trailer supply, same answer, etc. While not a common size the main problem I am encountering is the cutout corner measurement. The curve is different and any modern replacement I have found leaves gaps. The dometic/seitz spec is 900x520. I have more numbers but this window is peculiar to Lance 830s. I would appreciate any help anyone who has replaced this window can give me. Thanks, Chris
Any luck on finding a replacement? Was headed to Idaho today and noticed my window was gone when I filled out about 3 hours away from home.
