In short, no. I have given up trying to get a match. We have talked to numerous rv salvage yards and looked at a variety of new windows. The problem as I mentioned in the previous post is the cutout corner fillet. There are several available that are close HxW but have a much greater fillet which leaves a gap at all corners. The solutions I’ve come up with are either to fill that gap or to create a thin spacer on the outside that would cover that gap. Part of the problem is the inside clothing rack on the top and a cherry clothing compartment I built for the bottom. It is the passenger side upper window. Very little extra room. Btw the screen/shade is totally separate and could possibly be used on a window with similar dimensions. I have pretty much resigned myself to filling in or covering the corners. Up to a few years ago there was a replacement available but to my understanding that is no longer made. Please post if you find a good fit. Good luck, Chris
