A couple things, I ordered a different part number but it crossed to the mg16rw that Tcliche found. Different distributors, same part. If you’re comfortable with Alibaba go ahead and order. What I have seen on Amazon is the window comes in and out of stock. I’ve seen them run out a couple times. You might consider what we. did and order two so you can match across the interior. Added advantage is you then have a spare in case one of the remaining two goes walk about. Lastly, I’m sure you have, but read all the texts on this post. There’s some good installation points. Also, I keep a plastic card clamped to my rear view mirror with a checklist prior to departure. Prominent on that is window latching. Good luck.
