Camper_Jeff___K
Jul 28, 2022Navigator
First off, Solar panels do not discharge energy into the night.
Solarnight discharge
The back flow diodes and solar controller will prevent it. There is a minor voltage Vbf but it's very small. Also, it doesn't discharge back into the either or sky, it's just a resistance load to the batteries.
Most modern solar electronics have some sort of circuit protection. Even so, since you seem to have power in the day with sun, I would guess your solar charge controller is functio I g to some degree. Since your battery dies quickly, my guess.is.you damaged your batteries BMS. You'll have to do or have done, your own testing. Good luck.
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
