Jfet's avatar
Jfet
Our custom true flatbed truck camper build thread
Ok, I am going to collect random thoughts and progress pictures and put them here in a thread.
Goal: Construct a true flatbed camper with cabover, no slideouts but full 8 foot floor width inside. This will mount on a 2006 Isuzu NRR truck with a GVWR of 19,500 pounds and a current dry weight of 8700 pounds. The truck has a 20 foot flatbed that is 8 feet wide. The camper will take up 11 feet of the flatbed and the remaining area will be home to a future garage for our toys. We will install a hitch so we can pull our 17 foot Montgomery sailboat (trailer + boat is about 2200 pounds). The camper and garage will be removeable so the flatbed can be used for other purposes, or in case the truck needs extensive shop repairs down the road. Or if we are in Alaska and want to go pick up 3 cords of firewood or something :-)
Here is a picture of the truck with some important dimensions:
  • Randu wrote:
    Neat concept. I'm hitting "subscribe" so I can watch this thread and follow your progress.Just keep adding to this thread so its easy to track. Randu
    X2
    I've had thought's of building a TC someday too. It will be interesting watching your progress.
    I've looked at your drawings and was hoping you could comment on camper placement and weight distribution of the final placement of your TC and garage space on the truck. I see you have over 10,000 lbs of GVW left to work with but if you don't balance that over the rear axle I wonder if you will severely over load the front axle. I wonder if that Isuzu motor is taking up most of your front axles weight capacity much like my diesel engine takes up almost all my trucks front axle weight capacity. So basically I was just curious if the TC was going up against the cab because most of the weight will be forward of the rear axle or will it be mounted more rearward? Thanks and good luck with your awesome project!
  • Picked up a nice 25" x 70" Hehr door on ebay and a 15"x30" double pane Kinro slider window. Still need a egress window for the cabover and another small window for the bathroom.
    Ordered a Norcold N641.3R 3 way 6.3cuft fridge, Atwood Everest Star 7920 II furnace, Atwood 6 gallon gas/electric/DSI water heater, stainless steel range hood, and some hatches and vent covers for those. Will need this stuff to figure out how to frame the walls. Will need other stuff too obviously, but searching for good deals takes time.
    I am stuck on the camper jacks...leaning toward the Rieco-Titan 4 pc electric with wireless remote, 36 inch travel, 2500pounds/6000pounds for around $1800 at Dyers...but have read a couple of posts that the electronics are garbage...
  • Neat concept. I'm hitting "subscribe" so I can watch this thread and follow your progress.Just keep adding to this thread so its easy to track. Randu
  • This past weekend the wife and I cut out the 1x2 sections for the base on a 7x12 bandsaw (glad I had that!). I decided to make the outer perimeter 11 gauge and the inner cross members 16 gauge. Always keeping an eye on weight, but a lot will be welded to the outer perimeter base. The wall design is going to change a lot this week from the initial lion cage design I did for a weight estimate. There will be doors, windows, hatches, and some triangulation for strength. It was nice to get started on the floor though.
    Oh, and I bought 8 camper jacks at Camping World, then welded supports to four of them. These greatly aided in getting the base frame dead nuts level..and we cut the members to 1/64" accuracy...insane...the temperature of the garage probably makes it contract more than that on a cold day.
  • Picked up a Miller 211 MVP 110/220 volt MIG welder and some 1x2 in 11 and 16 gauge.
    Practiced for a few days (have a tig/stick welder, so not totally new, but the MIG is hot glue gun easy!) and have started producing *ok* welds....good enough for government work (at least at the state level).
    (Ignore the silicon in the weld, that is evidently normal for MIG)
  • I did a quick CAD drawing of what a steel frame might look like for our dimensions. I used 1x1 and 1x2 steel tube (with a little bit of cnc work on the curve section and a little bit of pipe). I have arranged things such that 2 inch R5 foam can be installed everywhere and there will be no place inside where there is not at least 1 inch of foam between the steel and the inner wall. This should help with thermal isolation.
    Most of the steel is 0.065 gauge but I used 0.120 for the corner vertical 1x2
    The total weight as drawn is 580.8 lbs
    3749" of 1x1 1/16" 258.3 lbs
    2067" of 1x2 1/16" 218.7 lbs
    426" of 1x2 1/8" 80 lbs
    197.25" of 1" round 1/8" 18.5 lbs
    75" of 2" wide 1/8" plate 5.3 lbs
