Re: Jack mounting plate pulled away from camper - repair?
unbob wrote:
A car backed into one of my front camper jacks and consequently the mounting plate was pulled away from the camper. Fortunately, no serious damage was done to the camper itself but the mounting plate was bent and needs to be straitened at a machine shop.
So, my question is what is the best way to re-mount the plate such that the attachment to the camper will be at least as strong as the original install? The TC is a Bigfoot with fiberglass exterior.
My plan is to drill out all the screw holes, fill with Gorilla glue and insert appropriately sized wooden dowels. Let dry for several days and then re-drill all holes for the correct screw size and install plate using original screws.
Does anyone see a problem with my plan? Is there a better way?
I have in fact done this same thing several years ago with a rear jack mount plate. It was successful and I've never had a problem. But of course the front jack bears substantially more weight when removing the camper from the truck so the repair had better be rock-solid!
All comments/feedback welcome!
Placing a call to Bigfoot and asking them what they would do in this case would be one of my first plans of action.
No RepliesBe the first to reply
