mkirsch
Jul 10, 2019Nomad II
Probably a wise decision. I know you said "9900lbs towing capacity" but that's with NOTHING in the bed of the truck. While I'm sure it's been done before, it's still asking pretty much everything your truck can give and then some.
On the extension, you can frequently if not always run a 6" shorter extension than you have overhang. The ball can be right underneath the rear edge of the camper, or even a few inches forward, without causing a clearance issue with most trailers. For example with my 18" overhanging camper, I'm using a ~12" extension.
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
