- ajridingExplorer IIA class 5 hitch with long extension can handle 1,200 lbs tongue depending on the hitch. Horse trailers tend to have the wheels all the way to the rear which puts a lot more weight onto the front of the trailer - where typical campers cargo trailers have axles more towards the center than the rear.
Use a longer trailer tongue if you can. You can have those extended by a welder. The risk is hitting the camper in turns (and when off-roading, which horse ppl dont seem to do other than a field).
Most extensions only see 300 pounds or so from campers or cargo trailers which is not as great as a heavy horse trailer with horses will make - GeewizardExplorer
Buzzcut1 wrote:
well one of the above posters referenced me. I have a superhitch, 48" supertruss, Husky weight distributing hitch with 1200 pound bars. If I was going to do it all over I would only make one change. Superhitch Magnum (not made when I got my setup). You are towing a trailer with live animals. Its a completely different consideration from those towing box trailers. I am not risking my horses lives to save a buck. The superhitch, 48" supertruss with a WD hithch is rated to safely deal with a 1200 pound tongue weight. nothing else comes close.
Thanks Buzzcut1. The key words here are live animals. I'll look into the Superhitch and Supertruss. - Buzzcut1Nomad IIwell one of the above posters referenced me. I have a superhitch, 48" supertruss, Husky weight distributing hitch with 1200 pound bars. If I was going to do it all over I would only make one change. Superhitch Magnum (not made when I got my setup). You are towing a trailer with live animals. Its a completely different consideration from those towing box trailers. I am not risking my horses lives to save a buck. The superhitch, 48" supertruss with a WD hithch is rated to safely deal with a 1200 pound tongue weight. nothing else comes close.
- Lindarae7776Explorer
two or three horse trailer aluminum trailer?
- Grit_dogNavigator III
Huh? Been dead for 5 years.
- hot_rodExplorerYears ago I hauled an 10 1/2" camper and a 4 horse dressing room trailer. I had a 40" extension built for the trailer tongue and ran that for about 8 yrs
- burningmanExplorer IIIn many years of hauling a large trailer behind an 11.5 foot camper with a stretched trailer tongue instead of a hitch extension, I’ve never had any issue with the trailer hitting the camper. I don’t have any heavy junk to attach and remove whenever I load my camper, either.
- GeewizardExplorerThanks all.
- trail-explorerExplorer
Geewizard wrote:
Did you use any kind of hitch extension to do it?
If the camper extends past the rear of the truck, then yes, you will need a hitch extension, otherwise you run the risk of the trialer contacting the truck when turning. - trail-explorerExplorerI've towed a lot of trailer equal in weight or heavier than a two horse trailer while camper is on truck.
- jaycocreekExplorer III used to haul a single axle two horse trailer loaded to the hilt with hay on top for two weeks way back in hunting, with an 8ft overhead TC with a standard hitch on a beefed up GMC half ton pickup..this was on one of Idaho's roughest washboard roads,the middle fork of the Boise river to Atlanta Idaho..
If possible,I choose not to use an extension , which means a smaller TC..I do use an 18" solid bar extension with my currant 9.6 for TC but I just haul a 17ft trailer with a Yamaha rhino on it and gear...
Anything larger than say 18" for an extension really gets spendy and puts your actual trailer hitch in question..the whole setup is for rich folk..(Laffin) - WyoBullExplorerFor a horse trailer, because of the weight, I am thinking you are going to want a Torklift Super Hitch and Super Hitch extension.
I don't haul that heavy with my Northern Lite as I just haul an ATV trailer. I do know somebody who also has a Northern Lite and she hauls her two mules all over the place and she has a Super Hitch and Super Hitch extension on her Ford Super Duty dually.
About Truck Camper Group
266 PostsLatest Activity: Jan 18, 2026
