Joe417 wrote:
What I'm seeing here isn't bad manufacturing by Northwood's but it is bad manufacturing by the plywood manufacturer. It looks like several of the plys all met at the same glue joint which was a failure just waiting to happen. There's hardly any way the plywood user could tell it was glued that way. It was great that no one was hurt. ..
Look again - it's not a plywood failure. Plywood is not glued like that - that was a sawed panel pieced in.
... and even if it WERE a plywood failure, there are four big bolts to hold a steel plate to the plywood floor.... but only some small screws holding the floor to the rest of the camper. Terrible design.
