anutami wrote:
I will be going with Torklift Tie downs from here on out.
Unless the anchors pull loose from my camper, I could not imagine the force that it would take to destroy the front and rear frame mounted Torklift tie downs or Torklift Fastguns.
The things I do not like about the Happijac system - the holes through the bed; the ears that stick out between the cab and bed; and the button mounts on the bumper.
I could see enough flex from one mounting point giving way that then would allow enough leverage and wrenching of the other mounting points to be torn loose.
