emcvay's avatar
emcvay
Explorer III
Dec 27, 2024
Wow! 2 years! Hi folks, update on my 990
Wow 2 years!  And now part of Good Sam?  Didn't see that happen but I've been super busy.
I came in today looking for a thread on my AC unit that I smashed and had to replace (which I thought I'd posted in here but I guess not??).  Then I realized it's been a while.
I still do YT so have been super busy with my channel which is starting to take off so I'm working full time at it now (retired).  Anyway, here are the updates and soon to be updates on my camper which after 5+ years we still love!
Installed 2 Vatrer heated LiFePo4 batteries to replace my FLA's/Marine batteries.  I've gotten into solar a lot more at the cabin and have started on the camper.  I also have power stations that I can plug the camper into, or use on the road but plan to install an inverter in the future but putting in those two batteries greatly increases my battery power (I just had to put in the newer DC Converter that is made for them).
I've also tested out a DC to DC charger that will give me 600w of Alternator charging once installed which is 2/3rds of what I need to run the new AC unit I plan to install and I have 200w of solar to install (Flexible panel) and a new charge controller to go with it which will get me even closer to what I'd need to run the AC full time while driving without needing the generator.
I'm thinking of installing an automatic generator start switch to back up the solar and have one in mind, just need to decide if I will or not ๐Ÿ˜‰
Another project I have going is installing a 4kwh battery in the box of the pickup in front of the wheel well (so not in the way of the camper) and plumbing it into the 'solar input' of the camper (which is a direct connection).  I could just parallel it there I suppose but am thinking of installing a charge controller instead (basically the controller doesn't care it's a battery and will provide any extra power needed on the road).  That would give me 6.5kwh of battery backup in the camper and with the DC charger and 200w solar I should be set for most conditions.
With the addition of a 2kwh power station I can also add ass needed and two 400w foldable solar panels (which I'm testing now) I hope to greatly reduce the propane I'm running.
As for the AC unit, I've been offered a new DC Air conditioner that puts out 10,000 BTU's and may be slimmer that what I'm running now.  If it works out I think it might be a game changer for us in moving away from burning too much propane in hotter weather to run the AC unit.
So that's the techy side of things.
We've not gotten out as much as we'd like but did make it out to Shaniko Oregon and Little Nache's this year and the Oregon coast last year as well as Northern BC.  In 2025 we have another Northern BC trip planned (my son lives there) and more local adventures.
  • Ya the forum is a joke now. But still entertaining from time to time.
    god bless yall who still try to help the few 1 post wonder lost souls that show up!
    Happy new years!
  • emcvay's avatar
    emcvay
    Explorer III
    Sad to see that.  I've seen it happen too many times usually due to FB though.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      ya, this was more because of a format change (new software that is a little not what we were use to.)  good same owned it for a long time before this. It didn't die because they took it over but rather because of the software mygration and issues related to that.  there are some changes coming soon hopfully that will make it a little less confusing.  other than that, its not to bad once you get use to how it is setup and works, but you know how change is to us old people ๐Ÿ˜‰
      where in Northren BC were you at?  probably drove right by me haha.
      • emcvay's avatar
        emcvay
        Explorer III
        Chetwynd and yes, you likely drove right by his place ๐Ÿ˜‰
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    Welcome back to the old RV.Net forum.  GoodSam took it over and the new layout killed it with 90% of the truck camper folks and most of the mods leaving.  Some of us still visit most days, but it really quiet on here.
