Dec-29-2021 04:54 AM
Dec-30-2021 03:55 AM
Surgtech94 wrote:
Thank you. Appreciate the information. No we probably won’t boondocks unless absolutely necessary. What I would like to do, is to have an end destination and on the route to get there stay maybe 2 days and on the way home, maybe stay a little longer at some of those places depending on location
Dec-30-2021 02:15 AM
valhalla360 wrote:Surgtech94 wrote:
The 1000W pure sine wave inverter is a generator? Is there anything like adding another battery? Our TT does have the ability to add solar. I might have to check this out
No it is not. To make an inverter work, you need an inverter, battery bank (large enough to feed a 1000w inverter) and a means of recharging (often solar but it doesn't have to be)
The real question is are you interested in boondocking...if not, you don't need solar or generator at all.
While driving, you truck will charge the battery and when connected to shore power, the onboard charger will keep the battery up.
If it's just a quick overnight and you don't need air/con or other high power items, you can get by with just the single battery that comes standard. It's when you want to stay off grid for multiple days where solar & generators start becoming standard items.
As far as water, it's nice to have a bit in case you need to use the bathroom while on the road but unless you are planning on being away from utilities, no sense carrying a full tank.
As retirees, look to slow down. We shoot for 100-150miles per day and rarely travel on back to back days. This avoids a lot of need to stop frequently.
We usually have a rough plan a week out and call up a day or so ahead of time to make sure they have sites.
Also look at weekly or monthly rates. They are typically much cheaper.
Another option especially if only staying overnight is Passport America or Boondockers Welcome (there are some other programs also). These are discount/free stops but typically have significant limitations that make them unsuitable for family holiday travel but for full time travel, they can be used to your advantage.
Dec-29-2021 08:47 PM
Dec-29-2021 03:33 PM
Veebyes wrote:
Load her up & head on out. No need to go overboard. If you bought everything recommended here you would need a tractor to pull it.
Keep it simple. A portable genny is good to have. Never know when you will be in a no choice dry camping situation & need to charge the battery bank. Solar is great for the hard core boondockers but for the average long distance traveler who only dry camps occasionally solar is a stretch. Enhancing your battery bank & installing a 1000W pure sine wave inverter makes life much more pleasant for using the no services BLM & other great camping areas of the west.
Carry some basic tools that you know can be used on the trailer but don't go overboard. Bring what you need to change a tire yourself. Roadside assistance could be hours away, even near a major city. Basic spares too. Fuses, lightbulbs, that sort of thing.
Push comes to shove look around the CG somebody has the tool that you need. Just look for the campsite that is obviously not a newb. Right there is your rolling Lowes.
Dec-29-2021 03:21 PM
Dec-29-2021 02:57 PM
Matt_Colie wrote:
OK Surg...
You have a lot of answers here, but it is clear that you are off into territory that you have not charted yet...
You obviously know how to live in a TT, but you have never used what you have to it's full potential. You have a lot to learn, and none of it should be painful. You will discover some things that matter and some that are just small inconveniences. Those of us that were born knowing all about RVing never had to put up with this. (yeah, right)
We traveled with two dogs (one has gone on ahead) in a motorhome shorter than your TT. We only made reservations when we were headed someplace we expected to be crowded (like Yellowstone) or a rally (those kind of come with reservations). At departure we always had an empty black tank, a full potable tank and provisions for three days. I always arranged the first travel day as a late start. Sailing taught me that departure mistakes often happen because your were in a hurry to get going. You (like us) are retired now, so don't rush for anything you don't really have to.
First, about your new TT (in my terms). If it has a potable tank, it must have a water pump. This would be run off the house battery and there is probably a switch that needs to be on. Don't leave it on when traveling, if a tap rattles open, there goes all you fresh water. For the cost of the weight, fill it with good water before departure. If you have not used the tank, do a disinfecting pass before you do. Many use bleach for this and I use H2O2 and have for years.
You have a refrigerator, use it as planned. I am guessing it is gas and electric. Either way, for a driving day in most weather, it can be off all day. If you are carrying a lot of frozen food, this may have to change.
You are not practiced at long driving days. (4 hours isn't long) So, when you start doing that, look for highway rest areas to be "grass stops" for part of your contingent. Small city parks work too, but truck stops frequently have near zero grass. Carry the bags you will need.
If you TT is like every other new RV I have seen, the installed house battery is inadequate. You will want to both upsize it and get a portable generator when you get going. There are myriad of other things you can do to make travel both more simple an less demanding, but you will have to come back here and ask questions when you can put words to them. Then we can be a big help.
When you can fully understand what your TT can do for you, there is a world waiting out there.
For long travel, find RV parks for a single night is a serious PITA and costs way more than it is worth. When you get a plan started, come back here for other ideas. You have enough to work with for now.
Edit addition:
You sort of asked about Boondocking/Drycamping. This also includes Lotdocking and Blacktopping (and stealth camping in our case).
Boondocking is specifically (if you are to be accurate) camping someplace with nothing available but fresh air. Probably not even pavement nearby.
Everything else is Drycamping or one of the others. You still have now utility support, but there is stuff nearby. This is what rest areas, Walmart and other welcoming businesses are for. Why by the whole farm when all you want are a few eggs??
You might look at the Harvest Hosts and Boondockers Welcome sites for some ideas there too.
If I can be of help, I'm here a lot or you can private message.
Matt
Dec-29-2021 12:53 PM
Dec-29-2021 12:02 PM
Dec-29-2021 11:40 AM
Dec-29-2021 09:48 AM
jdc1 wrote:
30 years of RVing without a surge protector. If you want to run your AC with a generator, you'll need 3,000+ watts. High end = Honda or Yamaha. Decent = Preditor or Champion. A lot of areas (Utah during spring and fall) get full fast, especially near national parks. Gotta have reservations well in advance for those areas. I just fill my water tank before I leave. I usually boondock on the first night of travel. Driving time should be limited...stop and smell the roses. It's those little out of the way gems that people miss that you might remember for the remainder of your life. Got a hobby? Check your route for the obscure towns that have something you are in to. My wife loves to quilt. Hamilton Missouri is nothing but a quilter's paradise. Yea...she made me go there for an entire day, even though it was 2 hours in the opposite direction of our travel. These are the things that make a real vacation more memorable. Slow down. You are retired now. No more having to be home on Monday to go to work. That 4 day weekend? Toss it. Take 7-8 days now.
Dec-29-2021 08:34 AM
Dec-29-2021 08:32 AM
Bud
USAF Retired
Pace Arrow
Dec-29-2021 08:05 AM
Old Days wrote:
Also think about how you will charge your batteries, I like solar but a generator also works.
Dec-29-2021 07:10 AM
Dec-29-2021 07:04 AM
Surgtech94 wrote:
Thank you
We’ve only done W/E hook ups in State Parks. I think we have almost what we need for FHU, hose, dump connectors and hose, filter. But will probably need a regulator to not blow the lines? We also need to get a surge protector - any recommendations, appreciated. Any good apps for campgrounds? Or do you just print off the information on your route?
