MR_MAC's avatar
MR_MAC
Mass to Pidgen Forge to The Smokey
Sepember trip, down I81 to Christianburg, then down I40 camping at Pidgen Forge and at Smokys (Elkmont area camping) sight seeing with car. After that need the best RT. to get to asherville from Elkmont. "Question" Roads, RT 441 through Pidgen Foge, Gatlinburg to park in to Elkmont CG. Then RT 321 to I 40. Driveing a 33ft Moter Hme. with toad. Thanks for any info. Rob.
  • Verry good info, sorry for the late "Thank you" out in the Maine woods with no wi-fi.
  • X2 on the advice above as far as the route. September can be quite busy here with the leaf peepers and Elkmont might be full. Another option for you is to stay outside of G'burg on 321 (use exit 435), that would make it convenient to get back to I-40 and be only 10 or so miles out of the city. Smoky Mountain Premier Campground is big rig friendly, fairly new at only 2 yrs. old and gated. Lots of other choices on 321 too but this one was built with motor coaches in mind. Heads up on a stop at The Island, you will see a very big ferris wheel if you go down Veterans Pkwy, That's the new entertainment complex "The Island" and I think its a "must do" stop with a Margaritaville and a Paula Deens restaurant along with some kitchy stores. And stop at Bush Beans too as you will go right by it on 411. Good café for lunch and a cute museum on the Bush Bean history. Its at the rt. 92 junction, and don't go up 92 or you will come into Dandridge that has a VERY narrow bridge. Not total disaster if you do as you will be able to turn around at the marina just before the bridge. Enjoy your visit.
  • That is the way to go into PF and back out, but you will don't want to go through downtown Gatlinburg in a MH. The streets are narrow, crowded and NOT made for large vehicles of any kind.
    To get into the Elkmont area, go I-81 until you run into I-40 (across the TN line, not near Christiansburg). Head east on I-40 for several more miles to exit 432A (Newport exit). At the intersection, take a right, then the FIRST left onto Rt 411. This will head into the back side of Sevierville. Go approximately 15 miles until you get to traffic light 17.3, where you will take a left onto Veterans Memorial Highway. After a few miles, it will turn into Dollywood Parkway. You will pass Dollywood and come to the end of that road. At that intersection, take a left toward Gatlinburg. (You will have bypassed all of the traffic of Pigeon Forge). Take the Gatlinburg bypass and head on toward Sugarland welcome center. Take a right just past the welcome center and you will be on your way to Elkmont without hitting all the traffic in the PF and Gatlinburg area.
    Just so you know, Rt 411 is a two lane, curving road, but is used by many RVs, semi-trucks each and every day, just be aware that there are some large curves and pace yourself, you will make much better time on this road than sitting in traffic on Rt 66 coming into Sevierville.
    Another heads-up: On Rt 411, just past the Bush Bean plant, 411 goes off to the left and Rt 92 goes straight ahead. Do NOT follow Rt 92!!
    We travel this highway each and every time we go to PF or Gatlinburg. We are pulling a 36' fifth wheel.
    When leaving Elkmont, I would just re-trace my steps to I-40 and head on east toward Asheville. Rt 321 goes through downtown Gatlinburg and I would avoid it in a MH. We usually try to avoid it in our Ford F-250 pickup truck because of the width of it with the mirrors. If you have your toad out, drive through and check out the narrow roads and then you can make that decision yourself.
  • I wanted to give you a heads up, I trailered home 81 from that area yesterday, there is construction SB in VA that had traffic backed up 7 miles, this was mid day and believe around mile marker 150. I hope that you don't get stuck in it.
  • You do know that there are no hookups in Elkmont CG. We stayed there in a 30' with toad, no problem, but not the best sites we have stayed at. Much better suited for smaller pull behind trailers. Go prepared with full water tanks, and empty waste tanks.
