โDec-25-2019 12:59 AM
โJan-10-2020 01:55 PM
Veebyes wrote:
It got down to 62 degrees this evening. Talked about lighting a fire but settled for simply closing the windows & putting something on over T shirts.
Kinda cool outside today. Did some fiberglass work on my boat & the usual amount of hardener in the resin made for a long time for it to harden. Tough dealing with these harsh winters.
โJan-09-2020 05:36 PM
โJan-09-2020 01:48 PM
โJan-09-2020 01:02 PM
โJan-07-2020 03:42 PM
โJan-07-2020 03:07 PM
โJan-07-2020 01:49 PM
PA12DRVR wrote:
Re: Caribou hunt
No animals taken on that hunt:
- It was too cold for there to be much movement, so limited opportunities in any case;
- For the few days that we were strategically staying put (vs. trying for fire up and fly back to Los Anchorage), the prime objective was to ensure the woodbox was full, that the woodstove was either freshly stoked or cleaned of ash and then fired up, and that the snowmelt buckets were full and placed on the woodstove.
- After doing all that, given the time of year, we had about 3 maybe 4 at the most hours of daylight; the hunting involved heading out on snowshoes, so by the time one builds in a safety margin (to ensure return before dark) and when one travels carefully at -40 to nearly -60 (carefully = slowly), one doesn't cover much ground. The quonset hut was on the end of a narrow lake, with two small valleys on either side: We covered those valleys, but not much more over the 4-5 days we went out....simply saw no 'bou.
...and even though we degreased and graphited our firearms (using 70's technology), I suspect its debatable if they'd have fired properly even if we found something to shoot at. We did shoot quite a few ptarmigan nearby with the old exposed hammer(s) side-by-side shotgun that the guy kept at the hut.
โJan-07-2020 08:19 AM
โJan-07-2020 01:52 AM
PA12DRVR wrote:
On that caribou hunt, "back in the day" (of my long lost youth), two airplanes / 3 guys flew into a strip on the other side of the Alaska range and promptly landed on about a bazillion feet of fresh snow...had to swim out of the plane. At the time it was "only" about -10, but the most experienced guy said "Let's drain the oil, just in case". So, on the first day, the last 3 hours of daylight were spent compacting the space around the planes, draining the oil into buckets and carefully carrying it to the nearby quonset hut.
Good thing: it dropped to -35, then to circa -50 and stayed there for about 5 days. The quonset hut had good wood stove...good thing because at -50, it had become a survival expedition. The 3 of us spent those few days tromping down a packed "strip" for an eventual departure. After a while, lo and behold, it warmed up to -25...which was noticeably warmer after -50+. The tall young buck (me in those days) promptly starts roping the frost off the metal wings and sweeping it off the fabric wings while the experienced folks heat the oil on the wood stove, carry it carefully out, and even more carefully put it in the engine...some preheating, then all hands work to pop each airplane loose from the snow and back to los Anchorage just in time to call off the CAP.
Memorable event even after 40 years.
While I've avoided outside work as much as possible since then (:) ), at anything below -20, things are done very slowly, very carefully, and with much forethought. At -50, a mistake (presuming one's "out of town") is probably deadly.
โJan-06-2020 01:48 PM
โJan-06-2020 01:02 PM
PA12DRVR wrote:
It's cooled off even in Los Anchorage area. The truck thermometer (FWIW) showed -11 at the house on Sunday a.m., -11 at Eagle River, and a cool -17 just north of Palmer.
Back in the old days (when winter was "normal"), I always used to figure that down to -20 was to be expected and, while not pleasant, just deal with it. -25, -30, -40 (or Purkeypile mine on frosty winter caribou hunt, -58) is just no fun and to be avoided if at all possible. My hat is off to the folks (troopers, linemen, wrecker drivers, and others) that just keep on going, regardless of the temps.
โJan-06-2020 07:41 AM
โJan-05-2020 12:47 PM
โDec-30-2019 07:08 PM
