doughboy's avatar
doughboy
half way there
will be heading to st augustine fl from columbus ohio. taking route 77
most of the way. looking for a half way campground. any ideas or suggestions??
thanks larry
  • USe google maps and in the search bar after you have pulled up whatever state you want to stop in, enter rv parks and campgrounds near and enter city and state in area you want to stop. A map will come up showing you the campgrounds in the area. You can then check them out to determine which one you would like. Or, try rvparky.com and rvparkreviewscom will list the parks by state and city along with reviews from campers.
  • Go to RVparkreviews.com and look around Charlotte or Columbia SC.
  • Here's a list of the tunnel heights on the BLP. The max height is measured at the center line of each tunnel. Be sure to know the height of your rig or you may be driving a convertible.
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,716 PostsLatest Activity: Oct 15, 2013
