Muddydogs's avatar
Muddydogs
Late Fall boondocking?
Hi guys, I'm new to the forums but not new to travel trailers. I have spent 20 years living in camp trailers of one kind or another while working in the woods. Most of the time the trailers were parked in a camp site with power and what not so that was never much of a concern. I have spent the better part of my life in the woods and I set a heck of a tent camp but the wife decided it was time for a trailer instead of a cot in a Kodiak tent so we are the proud owner of a Eclipse Iconic 27 foot toy hauler bumper pull. I guess I'm a boondocker although we just call it camping as apposed to changing city's which is all the campgrounds are around here.
A little about my trailer that will probably help with my questions. 100 gal fresh water, 50 gal holding tanks, 4000 watt on board generator, 35 gal on board fuel tank running ethanol free fuel, LED lighting, 2 27 group battery's, 2 7 gal propane tanks.
My biggest questions center around keeping my battery's charged while being out for 2 weeks in temperatures that can get down to zero degrees and keeping some water flowing in the trailer.
I plan on keeping my heater set at 60 degrees during the night and adjust during the day for comfort, most of the day light hours I will be away from the trailer so the heater will be off or set low if need be due to freezing conditions. I am hoping that I can get away with running the generator for just an hour or two a day to maintain my battery's but not sure if the converter putting out 14.7 volts will be enough charge. Would hooking up a 30 amp charger to the battery's be a better option?
As for keeping the water flowing my trailer tanks and intake hoses are exposed. I have insulated the intake hoses with some pipe insulation but figure that will only go so far. I plan on installing a Y fitting on the intake side of the water pump so I can run off of water jugs inside the trailer instead of the holding tank if I freeze up a line. I also figure some RV antifreeze in the gray and black tank should keep them some what liquid until I come off the mountain to warmer weather.
So what do you guys think? What else do I need to know?
Thanks Jim S.
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,758 PostsLatest Activity: Aug 27, 2013
