two_travelers's avatar
Nov 13, 2017
Myakka River State Park
Thinking of spending some time at this park in late March 2018. Can I assume that this park is packed at this time? How far ahead do we need to make reservations? Looks like there are 3 campgrounds, which would be recommended for a 27ft class A?
  • You may luck out seizing a cancellation if you check the website every day. Might also want to check out Oscar Scherer.
  • We make our reservations for the Palmetto Ridge loop the instant the reservations window opens 11 months prior to when we want to be there. It's pretty common the last few years that the available sites are all taken within a couple of minutes. We're skipping Myakka this winter, but will likely be back there next winter for a week or two. If we can get a suitable site...
  • I have stayed at Myakka a couple of times. As pointed out above, Palmetto ridge is the nicest section. Best to make reservations now if you want something in March. May be too late actually. We lucked out about a month ago, making reservations for April.
    With a 27 footer, you can probably find spots in any of the separate areas, so your options are expanded. I believe Palmetto is the only FHU site, but there is a dump station.
    Mike
  • Palmetto Ridge is the newest and nicest section of the campground. It has paved roads and full hookups and nice bath houses.
    The other two areas are all dirt roads and more plain in the woods sites. We have stayed here quite often and have seen the big flats area flood due to the rain.
    If you are sure of the dates I would start booking now as the snowbirds will still be here till April. Probably quite full from now till April, but may be able to find a spot.
About Campground 101
Recommendations, reviews, and the inside scoop from fellow travelers.14,723 PostsLatest Activity: May 09, 2025
