opnspaces's avatar
opnspaces
Navigator II
Nov 18, 2023
Are signatures now limited to two lines?
Are signatures now limited to two lines? My signature used to be three lines. All three lines are still in my profile. But no matter what I do I can't get the third line to show up. Should the signature box grow with what we have input there? Or do we need to start limiting it and stretching the signature out on one line?
  • My signature is in the personal info, but I just posted a reply and it didn't show up.
    I also don't see an option to add signature.
    • Cptnvideo's avatar
      Cptnvideo
      My signature showed as 2 lines - just "Bill & Linda" and "Arizona".  I removed the "br>" and substituted a comma and space.  Now it shows almost all of my signature, cutting off at the end of the second line.
        Cptnvideo
        After some editing, i got my full signature on 2 lines.  But I would prefer separate lines instead of commas.
  • Mine is a mess now too. I haven't taken the time yet to figure it out.
    • opnspaces's avatar
      opnspaces
      Navigator II
      I'm trying 4 asterisks between entries on mine.
      • dedmiston's avatar
        dedmiston
        Moderator
        LOL. Now it looks like you used a bunch of dirty words in your sig. ğŸ˜‚
  • It appears, given a little time, the software does go back and update prior signatures as the post above from earlier is now updated.
  • opnspaces,
    Thank you, this helps.  For some reason, I never saw that in the Signature box before, I went into the Personal Info tab too.  Now I see my entire old signature inserted in the Sig box, just no link to my picture.  I'm also seeing software code inserted where carriage returns would go.
    I just tweaked my sig to see how much and how many characters show up.  While it did save, it does not seem to be updated in my prior Comminuty messages.  Maybe it is not restorative.
    Let's see what it does here now.
    Thanks
    John.
    Sig to follow.   This is all one line, it word wraps
  • Hey John,
    On the top right of the screen click on your name or Avatar (far right side after Help and the little email icon) Then click on My Settings.
    Under My Settings click on Personal.
    Under Personal scroll over to to Personal Information tab
    Under Personal Information you will see your Signature (Third line down)
      opnspaces
      Navigator II
      As far as rules and guidelines that will have to come from a moderator or TeamGoodSam. I don't have any affiliation, just trying to help out other RV.Netters
  • Hi Opnspaces,
    How do you get to your message signature to edit it?    I searched for any wording to do with a signature and could not find it.  Did you?
    This used to be my prior RV.net sig. See below in blue.  And there was a camper pic at the bottom, which also no longer shows.    It appears I only get two lines also, which in my case is "John & Cindy" on one line and "blank" nothing on the second line as I had a space before the rest of the signature.
    Since at least two lines have come over, what are the new rules/guidelines for signatures and how to we get to edit them?
    John & Cindy
    2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
    CC, SB, Lariat & FX4 package
    21,000 GCWR, 11,000 GVWR
    Ford Tow Command
    1,700# Reese HP hitch & HP Dual Cam
    2 1/2" Towbeast Receiver
    2004 Sunline Solaris T310SR
    (I wish we were camping!)
About Community Feedback
We want to hear from you! What works, what doesn’t, and everything in between. Our team of Community Managers will address feedback in each release.188 PostsLatest Activity: Feb 11, 2025
