PNW_Steve
Oct 19, 2014Explorer
Almot wrote:PNW_Steve wrote:
To clarify: The only day that it used .68kWh it was 80F in the trailer and the fridge was at ambient. After the initial cool down the consumption has averaged .55kWh daily.
What were the conditions of use after initial cool down? Running it empty and with the door closed, or using it as you normally would with your home fridge, opening and getting things in/out every hour or so, running stove next to it, and so on?
Filled about 1/3 full. Door opened several times. Stove used once.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
