SJ-Chris
Aug 21, 2020Explorer II
200w solar system.....Lead acid OR AGM batteries?
I have two identical 2015 Thor Majestic 28a Class C RVs. One of them has two Lead Acid batteries (27s) in it, and the other has two AGM batteries. I am planning on adding a simple Windynation 200w solar system to just one of the RVs. Which one would you add the solar to and why?
The two lead acid batteries are brand new from Walmart (...they cost about $100 each).
The two AGM batteries are both 6 months old bought at the same time from the same place.
Does the fact that the solar system will keep these batteries pretty much topped off almost all the time (...these RVs are used about 60 days per year) affect your decision?
Is the overall difference pretty much negligible?
Should I put the solar with the AGM batteries since they are more expensive and it will help them last longer? (...is that even true?)
Let me know your thoughts.
Thanks!
Chris
Thanks!
Chris
