LittleBill
Feb 22, 2022Explorer
2112 wrote:
THIS may or may not help
Fusion is weird sometimes, you can do an offset plane off an angle plane, but not the other way around, unless you create the construction line first. I'm good now. I like this better anyway then draft, as I can prolly mirror the other side.
how come your not designing this? also fyi the hose thread is also different then mine, hose thread doesn't have a taper and requires a washer, the original does not match hose thread at all.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
