50 amp cord end
overhill7
Recently purchased a used 50 amp cord to use as extension.
Thought I would test it before hooking to rv. With a test light either the ground or the neutral will light the light on either hot side. Is that normal?
13 REPLIES 13
Bobbo
I am still wayne_tw wrote:
If I am reading this right,
1. the cord is not connected to the RV or an 50 amp outlet.
2. testing continuity, either hot side connects to the ground or neutral.
If that is the case, that cord has a dead short. It will immediately trip a circuit breaker, and depending on load, could create a serious, dangerous hazard.
I may be wrong, but the original post said he used a test light. A light won't light up without power, so I took that to mean the cord was plugged in.
Bobbo and Lin
camperpaul
Try Home Depot, Lowe's, and Menard's. In the electrical department.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
Bill_Satellite
This what I used to replace mine and it works great. I found it at Camping World but most RV dealers carry these.
Camco replacement plug
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
overhill7
Not sure but I bet you find on Amazon.
machunt
Not to hyjack a post but i need to replace the male end on my cord any suggestions 50 amp male end
Old-Biscuit
Now do a continuity test on each wire.
overhill7
Thanks all.I appreciate the fast answers.
RoyB
This is the normal method for testing a 50-AMP RV connector using an AC multimeter when shore power is applied.
This is typical wiring of a 30A and 50Amp Pedestal
Please exercise caution when testing the two HOT contacts as 240VAC will be present here.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
I_am_still_wayn
Bobbo
With the extension cord plugged into an outlet, you should have 110v Neutral to Hot 1, 110v Neutral to Hot 2, 110v Ground to Hot 1, 110v Ground to Hot 2, so yes, it should light up as you describe.
You will also have 0 volts from Neutral to Ground so the light should NOT light up, and 220v from Hot 1 to Hot 2 which may burn out your light if it wasn't designed for 220v use.
Bobbo and Lin
tvman44
Yes, perfectly normal as the neutral & ground are bound together at the main panel. ๐Ÿ™‚
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
rrupert
That doesn't seem normal. Is this cord a factory made cord with the ends molded to the cable? Are both ends configured to the same type plug, in other words, can you plug the one end of the extension into the other end? If so, there is something wrong.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
ScottG
Yes, normal because Neutral and ground are connected together back at the main panel.
Cheers,
Scott
