MPI_Mallard's avatar
MPI_Mallard
6V Battery Up-grade
OK,, Bear with Me,,, We have a Cedar Creek Daydreamer that came from the dealer with two 12V car batteries which later I found out that there was supposed to be four 6V deep cycle batteries but the dealer decided to save (his) money on the dealer prep and cheap out,,, so I'm here in Florida about to head north and It just occurred to me why not take four of the six NEW 6V Trojan cart batteries (I had to replace the six 2013 Interstate Batteries in the cart as the pooped-out pre-maturely due to storing them in my shed all summer in the Florida heat) this winter and use them in the fiver for the coming Canadian summer season and then stick em' back into the Florida cart when I get back in the fall this way I can maintain the six of them,,, right??
So,,, how do I hook four 6V deep cycle batteries up in my fiver??
Thanks in advance!
Red Green: All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business.
  • follow the diagrams posted here
    TIP
    connect jumper wire between (1) pair in series (aka make one 12v)
    then do the same to the other pair of 6v (make 12v #2)
    then wire the (2) new 12v packs in parallel (ignoring the middle jumper connections)
    a 12v battery has (6) cells, a 6v has (3) cells
    your new 12v battery has (6) cells house in different boxes, (3) in one box (3) in the second box , each pair of boxes is (1) 12v battery and is treated just like it only had (2) ends/posts
  • Hook them up carefully. Double check diagrams above. You'll be fine.
  • My 2000 model year FW had room for 4 group 24 batteries originally. I rebuilt the battery tray so that the taller 6 volt batteries would fit. I now use a floor jack to raise the whole pack of four 6 volts into place because they couldn't go in through the small door. I installed a residential frig last fall so I added two more six volts for a total of six and added more solar for a total of 1000 watts. The last 2 batteries that I added now ride in a carrier that is bolted to the frame just behind the rear axle. I'm going to make new cables for everything this summer so all the lengths will be equal but so far it's been working well.
    Your batteries will do better while under your care instead of letting them sit. Next winter while in Florida, if you need a battery in your rv just add a group 24 if you are plugged in all time. It will suffice if you need to move the rig. If you place four of your 6 volts in the original holder and add two more elsewhere you will have to consider the distance between batteries and use large enough cable. I have seen people on here mention that they have had issues when running six 6 volts so they may be able to tell you what they have experienced. They are probably not wired in a balanced manner and that's the issue I need to address with mine. My specific gravity checks ok on all batteries but I will be rewiring them.
  • The below is taken from this website.
    Wiring Batteries in Series/Parallel Combination
    In a Series/Parallel Combo Configuration the batteries are wired per the diagram below and the result would be a doubling of the voltage and doubling of the capacity. In our illustration we show four (4) 6V batteries with 225AH wired together. Each set is wired in series creating 2 banks, then the 2 banks are wired together in a parallel configuration. The result would be a battery bank that produces 12V and 450AH.
    Barney
About DIY Maintenance
