Passin__Through
Feb 22, 2021Explorer
Have you thought about using a locking turntable bearing, or perhaps a flat-mount slide bearing? A slide bearing would require some sort of fabricated locking mechanism though.
A turntable bearing would allow you to rotate the table so the corners should be out of the way when you sit down. With a slide bearing the table could be just pushed toward the opposite side, the slid back after you are seated.
Wishing you good luck in overcoming this challenge.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
