marcsbigfoot20b's avatar
Aug 03, 2017
Added Some Boondock
My trailer came with a group 24 battery. Upgraded 2 years ago to group 27 and had 2 GC2 six volt on the ground hooked in parallel.
Last 3 weeks in the heat, installed 2 grape solar 180 watt panels and a 30 amp mppt controller. Ditched the group 27 that had 2 bad cells and went with a Duracell AGM group 31. Converted a storage compartment about 8 feet away and added 2 more of the same AGM with 1/0 welding cable pinch crimped and soldered the ends.
Moderator edit to re-size pictures to forum limit of 640px maximum width.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 23, 2025
