Hermosa
Jul 10, 2013Explorer
JaxDad wrote:
If the second remote switch is wired correctly the hour meter on the original remote panel will still log hours even though you started the genset from the second switch.
Likewise, you can start it from one & stop from the other and vice versa.
The two switches are in parallel and the genset & hour meter don't know or care which one completes the circuit.
The reason I wanted the hour meter is it's digital, and I can tell when the genset is running. That's my current indicator that it's running. When on the road, it's hard to to tell if it's running if you aren't running the air or any otehr power equipment.If the switch had a light or an indicator the Generator is running, that would work too.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
