Bigbird65's avatar
Bigbird65
Andersen Levelers
After getting these levelers for the trailer I had to remove 1" of material from the pointed end of the leveler that goes between the wheels. I also beveled the pointed end and rounded the bottom back corner on my bench mounted belt sander.
The pull cords were added to make it very easy for my DW to pull the levelers out as I slowly back off of them. Works great.
I installed the big level on the trailed so that I can see it from the drivers side rear window. Sure makes leveling easy.
Also shown is the cheap but very effective chock that I built. Of course, one for each side.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
