SDcampowneroper
Apr 24, 2022Explorer
David,
rvs are built from the inside out, reverse of landed structures.
So, the cieling , wall and floor finishes should be complete and matching since they were complete before the divider wall was placed.
Most likely, that wall was placed BEFORE the outside wall and roof.
Look into other spaces like the ceiling and floors of bath, under bed, inside cabinets to comfirm continuity of material. If its so then that wall should remove with little noticeable effect.
Max
Max
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
