Sturgeon-Phish
Oct 15, 2014Explorer
Awning Arm Locking Pin
The awning extension is held out with a small retractable nub. As it wears or breaks it could cause a problem. I bought a couple of locking pins and after raising the awning into position I insert the locking pin to the next lower hole on the awning extension. Should the nub fail, the locking pin would prevent the awning from coming down unexpectantly, and could be a temporary fix until correctly repaired.
When not in use, they are inserted and locked on the extension arm in a lower hole.
Jim
Jim
