- bdlaiseExplorerI use 4 or 5 inch galvanized duct work for heating. I dulled the edges so it doesn't cut the awning. It stays in place while parked between outings. It's light weight and not expensive.
- rhagfoExplorer III
IAMICHABOD wrote:
TNGW1500SE wrote:
IAMICHABOD wrote:
As Chris said most use vinyl rain gutter but a Guy On Youtube used sewer pipe.
Looked like you could rip the awning putting it on.
I agree,I would NEVER try it.
I would disagree, I would sand the cut edges and take the rig on a 70 mph run late at night. I don't think the wind can get enough force under it to peel it off. - rhagfoExplorer III
TNGW1500SE wrote:
rhagfo wrote:
........We keep the rig ready to go at the drop of a hat, best time 90 minutes from walking out of work to getting 5er and on the road.
There's your problem! Quit working.
That is coming VERY SOON!!!!! - IAMICHABODExplorer II
I agree,I would NEVER try it. - TNGW1500SEExplorer
There's your problem! Quit working. - TNGW1500SEExplorer
Looked like you could rip the awning putting it on. - rhagfoExplorer III
Almot wrote:
Is it so important for it to stay on while traveling, that you are willing to risk loss of this item and safety of others on the road? If it flies off and hits somebody, are you going to tell them to sue Youtube?
Make it 2-piece and take it down for travel.
Also, check aluminum gutters - they are of different shape, might fit your particular setup better than vinyl.
If I did something I would not want to need to remove for travel! It would take too much to get going!
We keep the rig ready to go at the drop of a hat, best time 90 minutes from walking out of work to getting 5er and on the road. - AlmotExplorer IIIIs it so important for it to stay on while traveling, that you are willing to risk loss of this item and safety of others on the road? If it flies off and hits somebody, are you going to tell them to sue Youtube?
Also, check aluminum gutters - they are of different shape, might fit your particular setup better than vinyl. - LwiddisExplorer II"it may be able to stay on while traveling"
May stay on? - rhagfoExplorer III
2oldman wrote:
Probably best to read first.
What can I say started reply and walked away for a bit. :S
About DIY Maintenance
