RedRider16's avatar
RedRider16
Bad Window Seal?
 I Believe I have a bad window Seal on this window. It's been raining all day and the rain is coming in through the top of the window. My question is what should I buy to fix the issue? I don't have any experience with this
  • joelc's avatar
    joelc
    I had the same problem with one of my windows on my 5er.  I used the same stuff I use on the side of the RV (Lexel sealant).  However, I later found a pin hole on the edge of my roof where the water was coming in and repaired that with Dicor.  No leak any more and a reinforced window.  If you are getting a leak at window go from top to sides about 4" down.  No need to do the entire frame.
  • I ruined my last truck camper by using caulk to not seal a leaking window. It continued to leak inside the wall and rotted the floor. Remove the window, clean the old butyl tape and caulk off, and reset with new butyl tape.
  • Are you sure it's coming from the window? Could be the roof. Every year I re caulk all seams on the roof, windows, corners etc, with the appropriate Dicor.
    • RedRider16's avatar
      RedRider16
      Sorry for the really late reply. I have a awning on the window and I put it down after that leak and haven't had a leak since then so I'm thinking its the window or where the awning sits when its not out. Out of curiosity how would I be able to determine a roof leak?
  • Dicor Lap Sealant, probably the “no sag” line. The other possibility is to take the window out and reset it using butyl tape sealant.
      RedRider16
      I was thinking of pulling the window and reset it since it probably needs it along with all the other windows
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
