portscanner
Jun 24, 2019Explorer
Bracket to hold table leg - another 3d printed item
Got tired of the table leg rolling around when driving down the road.
So, I designed two brackets to hold it in place. The can be secured in place with screws or as I mounted it on the floor under the edge of the bench, I used double faced tape.
Make your own here on thingiverse.com
The design I have works with a 73 mm diameter leg. If you have a different size, you can download the cad files from the above link and re-size it as needed
