- BobboExplorer III have been doing Auto Zone batteries for years. Except for my pair of 6v GC batteries in the RV. Those came from Interstate.
- Harvey51Explorer
Pianotuna wrote:
I always put in the biggest meanest battery that fits the available space.
Yes, measure before going to the store.
I've had good luck with Costco. - jjrbusExplorerAs the years have went by I have become a fan of NAPA battery's. Then there is the northern and southern or hot climate battery.
Jim - westendExplorer
- BCRacing24ExplorerFord 6.8L V10
650 cca is standard
750 cca is "heavy duty" per Ford terms/manuals
Our 14 Thor Class-C came with the 650 cca - RJCorazzaExplorerI also get the highest capacity battery that will fit in the tray. For my 2 pickups that equates to 900cca. X2 on the Motorcraft longevity, although I replaced them after 10 years with Interstate batteries from Costco.
- 2oldmanExplorer IIGot owner's manual?
- westendExplorerI'm a huge cheapskate and that includes batteries. However, I got 10 years, 1 month out of my original Motorcraft battery and it was not lightly used. When I needed a new one, I replaced it with the same battery.
- pianotunaNomad IIIHi,
I always put in the biggest meanest battery that fits the available space. - Here is what Interstate says.Interstate
I would go to local big box store, auto parts store and get one with the same cranking amps, either 750 or above. Get one with at least a 60 month warranty or greater.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
