Hossrod
Dec 22, 2015Explorer
Creating new external hatches
Wasn't sure if this was better here or in Tech Forum. Please move if this is incorrect forum, thanks!
I'm considering making our bed bigger in our 1996 Class C which will mean that it will be extended all the way to the wall on one side. The walk area that is there now will be covered up. I would like this to be accessible storage space but a hatch on the inside won't be very accessible much past the first foot or so.
What I would like to do is build an external hatch door (like the other existing storage hatch doors from the factory) to be able to easily access the entire area.
My question is, what is a good way of doing this? Looking at the existing hatches, they seem to be custom constructed from extruded stock and cut to build a frame, much like a picture frame or cabinet door.
At the moment, I'm planning to see if I can find someone parting a trailer that I can scavenge an applicable sized hatch from, frame and all.
Is this a good approach? Should I be looking at sourcing some of the above mentioned extruded stock (no idea where from) and building my own? Are there hatch kits or maybe even prebuilt units you can buy that are better/newer construction that what was used 20 years ago?
TIA!
TIA!
